SWO frequency?
LACTIC
In my debugger settings I got there is some SWO frequency difference means before 2 or 3 days its frequency value is 10Mhz but now it is only 2Mhz and from last days I have getting some errors. So plz tell me that such errors are coming due to this change or not and how to re change SWO frequency ?
PA13/PA14 are used by the debugger, if you use them in the application they will prevent or break connectivity.
5 REPLIES 5
LACTIC
errors are
LACTIC
LACTIC
Thank You Sir.
Now my debugger is also enable after replace.
