STM32U575VGT HAL_FLASHEx_Erase() not working (page is not erased)
Adriano Melis
Hello all,
this code snippet is not working: the page is not erased, although the HAL does not report errors.
No RTOS is running.
if (HAL_ICACHE_Disable() != HAL_OK) {
Error_Handler();
status = HAL_FLASH_Unlock();
if (status != HAL_OK) {
Error_Handler();
erase_init_struct.TypeErase = FLASH_TYPEERASE_PAGES;
erase_init_struct.Banks = FLASH_BANK_1;
erase_init_struct.Page = 127;
erase_init_struct.NbPages = 1;
status = HAL_FLASHEx_Erase(&erase_init_struct, &page_error);
Error_Handler();
Any suggestion?
12 REPLIES 12
correct. I tried 15 WS without any improvement.
Adriano Melis
Attached two cube projects, mcb-fw-FLASH-IAP is for U575VGT (NOT working), IAP is for U575ZI (working on the Nucleo board).
As you can see the code is the same.
Adriano Melis
Hello all,
I found the source of the problem: the DUALBANK bit in FLASH_OPTR was set to 1.
On this device this arranges the FLASH page access in two banks of 64 pages each.
