STM32l152-VB _Start up
‎2012-11-14 2:40 AM
i need help
When debugging my code ,,there is an infinite loop at start up section,,,although i did all clk configuration
For example@file system_stm32l1xx.c /* Wait till HSE is ready and if Time out is reached exit */ do { HSEStatus = RCC->CR & RCC_CR_HSERDY; StartUpCounter++; } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));Is there any opinion for solving this problem?...Thanks in advance
#clive1- Mark as New
‎2012-11-14 8:04 AM
Do you have an external crystal, and is it starting?
If it's not starting you'd need to review the component choices, and perhaps the STM32 crystal app note.Up vote any posts that you find helpful, it shows what's working..
‎2012-11-17 5:19 AM
‎2012-11-22 2:49 AM
I have a similar problem with STM32L152xx
Configuration:Clock source: MSIfreq.: all MSI freq. (64KHz to 4MHz)Procedure- Power on- the device NOT start...- manually reset (NRST to GND for ~1 sec - from one to three attempts)- the device start...Very simple test firmware (schematic):{ [power-on] SetSysClock(); ConfigurePortAPin13ForToggle(); while(1);}NOTE - in debug-mode with SWD connected the device start normally at any freq. and also with HSE 24MHzThanks in advancePaolo- Mark as New
‎2012-11-22 6:24 AM
Is this demonstrable on an STM32L-Discovery board, or is this something else?
Are you using the CMSIS library, which is presumably calling System_Init() prior to calling main()?Up vote any posts that you find helpful, it shows what's working..
‎2012-11-22 7:05 AM
1 - No, the problem appear on a little and very simple board developed by us: uC in BGA package (STM32L151R6H6TR) with USB connection and EEPROM (I can send you the schematic or the layout...)
2 - Yes:LDR R0, =SystemInitBLX R0 LDR R0, =__mainBX R0
