STM32L communication between 2 USART
kitjazax
Posted on March 25, 2015 at 17:39
Hello all,
I 'm novice and
using STM32L152RE to do a communication between 2 USARTs
I use USART2 for recieving GPS Data and I would like to echo all recievied data without parsing on PC Terminal by using USART3 but I  only got a unreadable character return. Can someone please help me with it?
Thank you
12 REPLIES 12
Posted on March 25, 2015 at 17:58
The STM32 USART's don't output at RS232 compatible voltages.
Why don't you start by describing the board you're using, and the connections/pins being used. The GPS receiver used, and the baud rates at play. At least this way someone could mash up a simple example.
Post the code that doesn't work now.
Review other code
https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/USART%20Problem%20with%20nucleo%20L152&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&currentviews=123
kitjazax
Posted on March 25, 2015 at 18:58
thanks for your advise I connect the GPS reciever with 5V power supply and use 2 cables for connecting their tx and rx pins to uC(Nucleo l152RE ) here is my code
GPS reciever is Maestro A-2200 and working as 4800 Buad
#include ''main.h''
void RCC_Configuration(void)
  /* USART2 and 3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2 | RCC_APB1Periph_USART3, ENABLE);
  /* GPIOA clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB, ENABLE);
void GPIO_Configuration(void)
  /* GPIO Configuration */
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  /* Connect USART pins to AF */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_USART2);  // USART2_TX
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource3,  GPIO_AF_USART2);  // USART2_RX
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource8,  GPIO_AF_USART3);  // USART3_TX
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource9,  GPIO_AF_USART3);  // USART3_RX
void USART2_Configuration(void)
  USART_InitTypeDef USART_InitStructure;
  /* USARTx configuration ------------------------------------------------------*/
  /* USARTx configured as follow:
        - BaudRate = 9600 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = 4800;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(USART2, &USART_InitStructure);
  USART_Cmd(USART2, ENABLE);
void USART3_Configuration(void)
        - One Stop Bit
        - No parity
  USART_Init(USART3, &USART_InitStructure);
  USART_Cmd(USART3, ENABLE);
/************************ Function USART2 send String ******************/
void USART_Puts(char *s)
  while(*s)//check end of string
    while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET); // Wait until transmission ready
    USART_SendData(USART2, *s++); // Send Char
/*********************Function USART2 send Character *********************/
void USART_Putc(char c)
     USART_SendData(USART2,c); // Send Char
int main(void)
  SystemInit();
  RCC_Configuration();
  GPIO_Configuration();
  USART2_Configuration();
  USART3_Configuration();
  char tmp[50];
  int i=0;
  while(1)
    if (USART_GetFlagStatus(USART3, USART_FLAG_RXNE) != RESET) // Check for Full
      tmp[i++] = USART_ReceiveData(USART3);
    USART_Puts(tmp);
      i++;
      if (i >= 50)
        i = 0;
  while(1); // Don't want to exit
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
     ex: printf(''Wrong parameters value: file %s on line %d\r\n'', file, line) */
  /* Infinite loop */
  while (1)
#endif
Posted on March 25, 2015 at 20:28
Got some inconsistencies in the GPIO bank, pins and AF settings there. Stuff needs to be coherent.
Quick blind mod
#include ''main.h''
/* GPIOA and B clock enable */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_USART3); // USART3_TX PB.10
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_USART3); // USART3_RX PB.11 (in from GPS TX)
- BaudRate = 4800 baud
- One Stop Bit
- No parity
- One Stop Bit
- No parity
int main(void)
SystemInit();
while(1) // Don't want to exit
uint16_t Data;
// Pipe from USART3 to USART2
while(USART_GetFlagStatus(USART3, USART_FLAG_RXNE) == RESET); // Wait for Char
Data = USART_ReceiveData(USART3); // Collect Char
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET); // Wait for Empty
USART_SendData(USART2, Data); // Echo Char
* @retval None
'', file, line) */
/* Infinite loop */
while (1)
#endif
Mikk Leini
Senior III
Posted on March 25, 2015 at 21:15
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6gs&d=%2Fa%2F0X0000000btJ%2FH3QedEMV_5bq6wm_ybTos_RW64x4TSMzGfw2QlahfkI&asPdf=false
kitjazax
Posted on March 25, 2015 at 22:06
thanks for your kind.It 's really a big help for have your  code as reference
kitjazax
Posted on March 25, 2015 at 22:08
thank you very much for taking your time
to help
kitjazax
Posted on April 01, 2015 at 19:02
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6gO&d=%2Fa%2F0X0000000bt8%2F44QfoR0Fvo6NFasDKog8eum1_ZzXWtI8v8uUkN3uYTc&asPdf=false
Posted on April 01, 2015 at 20:37
You'll need some looping to wait for many characters, rather than just one if it happens to be in the receive buffer.
Posted on April 01, 2015 at 22:16
#include ''main.h''
- One Stop Bit
- No parity
- One Stop Bit
- No parity
USART_ITConfig(USART3, USART_IT_RXNE | USART_IT_TXE, ENABLE);
// Console USART Routines
USART_Putc(*s++); // Send Char
char USART_Getc(void)
while(USART_GetITStatus(USART2, USART_IT_RXNE) == RESET); // Wait until received character
return((char)(USART_ReceiveData(USART2) & 0xFF));
// GPS Routines
char GPS_Getc(void)
while(USART_GetITStatus(USART3, USART_IT_RXNE) == RESET); // Wait until received character
return((char)(USART_ReceiveData(USART3) & 0xFF));
#define BUFFERS 15
#define BUFFER_LEN 80
char rxbuff[BUFFERS][BUFFER_LEN];
char temp[BUFFER_LEN];
//check for first $ and store more chars into rxbuffer until
 then start new index and do the same ...
void checkNMEAdata2Buffer(void)
char ch;
uint8_t nr=0,pos=0;
while(nr < BUFFERS)
ch = GPS_Getc();
if (ch=='$') // Resync line
pos = 0;
rxbuff[nr][pos]=ch;
pos++;
if ((ch == '
') || (ch == '
') || (pos == (BUFFER_LEN - 1))
rxbuff[nr][pos]=0; // NUL terminate
pos=0;
nr++;
} // while
//get NMEA sentece form index
void getNMEAdata(uint8_t nr)
uint8_t n;
char ch;
for(n=0;n<BUFFER_LEN;n++)
ch=rxbuff[nr][n];
temp[n]=ch;
if(ch==0) break;
int main(void)
checkNMEAdata2Buffer();
getNMEAdata(0);
USART_Puts(temp);
while(1)
* @retval None
'', file, line) */
/* Infinite loop */
while (1)
#endif
