stm32H743Y vs stm32H743V
Franzi.Edo
Dear all,
I am facing to a stm32h743 issue. I have a Nucleo with the stm32H743 Rev Y that work perfectly. Now, I just tried the new Nucleo equipped with the stm32H743 Rev V. As expected, my previous code (Rev Y) does not work on the new device (Rev V). I noticed that it should be a Flash speed problem (if I slow down the PLL for the cpu clock from 400-MHz to around 100-MHz, my new board works). Now, the documentation of ST is really not clear about the procedure to set-up the Rev V. It seems I have to change "some" registers but the procedure is not evident. Any suggestion about how to set-up the Flash parameters for the stm32H743 Rev V?
Thank's
Edo
I believe this should work
  * @brief  System Clock Configuration
  *         The system Clock is configured as follow :
  *            System Clock source            = PLL (HSE BYPASS)
  *            SYSCLK(Hz)                     = 400000000 (CPU Clock)
  *            HCLK(Hz)                       = 200000000 (AXI and AHBs Clock)
  *            AHB Prescaler                  = 2
  *            D1 APB3 Prescaler              = 2 (APB3 Clock  100MHz)
  *            D2 APB1 Prescaler              = 2 (APB1 Clock  100MHz)
  *            D2 APB2 Prescaler              = 2 (APB2 Clock  100MHz)
  *            D3 APB4 Prescaler              = 2 (APB4 Clock  100MHz)
  *            HSE Frequency(Hz)              = 8000000
  *            PLL_M                          = 4
  *            PLL_N                          = 400
  *            PLL_P                          = 2
  *            PLL_Q                          = 4
  *            PLL_R                          = 2
  *            VDD(V)                         = 3.3
  *            Flash Latency(WS)              = 4
  * @param  None
  * @retval None
static void SystemClock_Config(void)
  HAL_StatusTypeDef ret = HAL_OK;
  /*!< Supply configuration update enable */
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  /* The voltage scaling allows optimizing the power consumption when the device is
     clocked below the maximum system frequency, to update the voltage scaling value
     regarding system frequency refer to product datasheet.  */
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); /* SCALE0 for 480 MHz */
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /* Enable HSE Oscillator and activate PLL with HSE as source */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
  RCC_OscInitStruct.HSIState = RCC_HSI_OFF;
  RCC_OscInitStruct.CSIState = RCC_CSI_OFF;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 400;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
  ret = HAL_RCC_OscConfig(&RCC_OscInitStruct);
  if(ret != HAL_OK)
   while(1) { ; }
/* Select PLL as system clock source and configure  bus clocks dividers */
  RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_D1PCLK1 | RCC_CLOCKTYPE_PCLK1 | \
                                 RCC_CLOCKTYPE_PCLK2  | RCC_CLOCKTYPE_D3PCLK1);
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  ret = HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4);
  if(ret != HAL_OK)
   while(1) { ; }
4 REPLIES 4
  *            AHB Prescaler                  = 2
  *            PLL_M                          = 4
  *            PLL_N                          = 400
  *            PLL_P                          = 2
  *            PLL_Q                          = 4
  *            PLL_R                          = 2
  *            VDD(V)                         = 3.3
  * @param  None
  * @retval None
  if(ret != HAL_OK)
   while(1) { ; }
  if(ret != HAL_OK)
   while(1) { ; }
Double check if it has same speed crystal for HSE.
Also V version can go up to 480MHz (i think)
Franzi.Edo
Thank you Clive and Linas.
Problem solved. It was enough to add the following instructions before the PLL set-up. The Clive code was helpful. Thank's
// Only for Rev. V
	PWR->CR3	  &= ~(PWR_CR3_SCUEN | PWR_CR3_LDOEN | PWR_CR3_BYPASS);
	PWR->CR3	  |=   PWR_CR3_LDOEN;
	PWR->D3CR	  &= ~PWR_D3CR_VOS;
	PWR->D3CR	  |=  PWR_D3CR_VOS_1;
Franzi.Edo
forgotten one line ...
// Only for Rev. V
	while ((PWR->D3CR & PWR_D3CR_VOSRDY) == 0);	 // Waiting for the vos ready
