stm32f7discovery cubemx driver ethernet LAN8742a
vrba1
Posted on December 22, 2015 at 13:04
Hello All,
When I generate code with  stm32cube for kit stm32f7discovery in file
stm32f7xx_hal_conf.h is generated driver for  DP83848_PHY_ADDRESS 0x01 , not for lan9742a
can you help me ?
Thank you
Posted on December 23, 2015 at 18:21
Hi miroslav.vrba,
You can modify the stm32f7xx_hal_conf.h with LAN8742A_PHY_ADDRESS.
STM32CubeMx is using the stm32f7xx_hal_conf_template.h as a template file, this is why you find DP83848_PHY_ADDRESS 0x01.
-Shahrzad-
