STM32F769i DISCO recovery to factory reset
kranthi.akssy
I have purchased STM32F769 Discovery Kit. I'm new to this board usage. I tried an led blinking example using STM32CubeIDE. After Debugging the code I lost the factory default code and now nothing is showing on LCD display.
Is there a way to get back to the factory reset mode with LCD display and default settings?
Kindly help me!
Ozone
Principal III
Not directly.
Once the Flash is erased, the code is gone.But the code you mention (usually called "demonstration project") is part of the resource downloads (software/firmware package), and you can directly flash it back onto the board.
I don't have a F769 discovery, but several other disco boards.
Ozone
Principal III
Not directly.
Thanks a lot!
