STM32F7 GUI
ihsen
Posted on May 25, 2016 at 14:56
Hello, I am trying to developed an application with STM32F7. I managed to integrate the GUI with stemwin (appears on the screen, it's ok) but the Touch screen does not work so I could not use the buttons of the interface. I need some help.
5 REPLIES 5
Walid FTITI_O
Senior II
Posted on May 25, 2016 at 15:32
I recommend you that you run and get inspired from “STemWin_SampleDemoâ€� example code in
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef7.html
at this path STM32Cube_FW_F7_V1.4.0\Projects\STM32756G_EVAL\Applications\STemWin\STemWin_SampleDemo
You can get further information from emwin user guide of  SEGGER
https://www.segger.com/downloads/emwin/UM03001_emWin5.pdf
-Hannibal-
ihsen
Posted on May 25, 2016 at 22:16
I tested the example “STemWin_SampleDemoâ€�   but not working (white screen)
Posted on May 25, 2016 at 22:38
Ok, but what board, specifically, are you using?
The EVAL demo probably isn't going to run on the DISCO.
Did the screen run with a demo app when you got it? Does reflashing it get you back to a working demo?
ihsen
Posted on May 25, 2016 at 23:31
thank you -Hannibal- I solved the problem
ihsen
Posted on May 25, 2016 at 23:33
Solution: STM32Cube_FW_L4_V1.4.0\Projects\STM32L476G-Discovery\Demonstrations
