STM32F7 discovery SD card access
manuel239955_stm1_st
Posted on November 07, 2015 at 14:59
I try to access to the SD card with BSP drivers.
BSP_SD_Init and BSP_SD_ReadBlocks return SD_OK, but the read buffer
does not reflect
the values in SD (the buffer is
almost always
0).
Can you help me ?
Thanks.
Posted on November 09, 2015 at 10:30
The application FatFs_uSD works.
So it seems that BSP_SD_Init and BSP_SD_ReadBlocks from BSP examples are insufficient to read the SD.
