STM32F429 USB Audio 16/24bit
nortowianski
Posted on March 21, 2016 at 07:51
Hi, I want to ask you if it is possible using HAL to change usb format audio from 16bit to 24bit and vice versa. Now I can choose in windows between different frequencies of 16bit sampling, but if I change usb descriptor and add 24 bit sampling - windows doesn't see 24bit (only 16bit). If I set only 24 bit sampling windows see it. Please help me.
nortowianski
Posted on March 21, 2016 at 11:18
I solved the problem. I have to change Input Terminal in usb descriptor.
Walid FTITI_O
Senior II
Posted on March 21, 2016 at 14:18
Hi ntow,
Thank you for your contribution and the experience sharing.
-Hannibal-
mr23
Posted on June 01, 2016 at 15:06
Hi, can you describe how to solve this problem?)
