STM32F429 and AMOLED screen
‎2013-10-26 2:51 PM
for my project i need to connect HTC Desire screen to STM32F429. it has 800x480x16b resolution, RGB565 standart. To get best peformance, should i use original SDRAM (like in SDTM32F429i_DISCO board), or it would be faster to use SRAM like IS61WV102416BLL-10TLI? And if yes, how much different programming would be, to be able run original STM32F429i-disco programs (Segger UI)? (i only should do config, and rest is fine ?, address looks like will be the same for FMC controller ) Also will i fit into this memory my design ? 800x480 use 384k*16, so with 1M*16 i should be fine ? Many thanks for any help on this question- Mark as New
‎2013-10-28 11:09 AM
I'd think the SDRAM on the STM32F429I-DISCO would be more than adequate, and 1/10th the price.
‎2013-10-28 1:31 PM
Since cost is no issue, if that gives 10% more speed or even lower, i use it. I just don't know much about memory, and bandwidth.
‎2013-10-28 2:25 PM
You may be want to think about that, and the requirements of the display.
The SDRAM on the DISCO has 4x the capacity (8MB vs 2MB), is 10x cheaper ($2 vs $20). The part you spec'd is also a BGA which also tends to be more expensive to use, increases PCB layers/issues/cost, fab and rework. The DISCO board is likely 4-layer, the EVAL board probably 8-layer.SDRAM is better suited to rastering applications like screens, or linear DMA access, exactly how beneficial will depend on ST's implementation, which I haven't thoroughly analyzed, but seems to have caching/acceleration which improve performance of the rather woeful external busing. M3/M4 designs are best suited to closely coupled memories, and reason to select the F4 over something better suited to large panels?Up vote any posts that you find helpful, it shows what's working..
‎2013-10-28 2:44 PM
I really don't want to use something that has more performance. Even STM32F429 is to much for the task, but i am participating in concurs, and i need to impress peoples, who will vote for my project.
It will be used in DIY reflow oven, STM32F429 coupled with HTC Desire touchscreen (http://youtu.be/eUg27cu6eFY)as well as AMOLED screen will be used for user interface, and PSoC will run PID loop for temperature control. I have large budget for this project, so i want to make it as fast as possible while using familiar parts. I guess that will be first oven capable of cooking and calculating Mandelbrot series at the same time :) I would use similar SRAM, just in TSSOP package.- Mark as New
‎2013-10-28 4:00 PM
Remember, something that doesn't work, doesn't impress anyone.
Consider if you can proof-of-concept the screen interface by modding an STM32F429I-DISCO board. Remove the screen, wire up the HTC screen. I see they are pretty cheap, but couldn't find an interface document quickly.[DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Discovery/stm32f429%20Disco%20direct%20to%20VGA%20Monitor&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/AllItems.aspx¤tviews=203]https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fSTM32Discovery%2fstm32f429%20Disco%20direct%20to%20VGA%20Monitor&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&TopicsView=https%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM32Discovery%2FAllItems%2Easpx¤tviews=203Up vote any posts that you find helpful, it shows what's working..
‎2013-10-28 10:42 PM
Are you talking about datasheet ?
I gone a long way trying to reverse engineer this screen, and i even get datasheet not only for panel, but for OLED controller embedded on glass. And molex has right connector, so i can make pcb for it. If some one are interested connecting amoled, let me know, i will share design files- Mark as New
‎2013-10-28 10:43 PM
‎2013-10-29 7:29 AM
A data sheet would be fantastic, I was fishing more for a pin configuration chart, ideally one with standard signal equivalents.
‎2013-10-29 9:39 AM
i have datasheet for SLCD and AMOLED ,
finishing pcb adapter for amoled, maybe you can help to set up LCD controller ? (files attached to this post) Hm, that is fun, i made pcb, it looks like working (inverters and so on). Now i don't know what exacly to write via spi and how :( in 2-3 weeks i will get adapter, so i can hook SPI decoder while phone is still working with screen, and that way extract all init data. I know all timings by probing lcd connector , so maybe at least this part will be easier. But for now, i don't know what to do, it a bit complicated for me, and i have way to much work in other areas so not much free time for this ________________ Attachments : ACX425AKM_Ver0.4_20100624_201306185709.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0ie&d=%2Fa%2F0X0000000bcw%2FiDcmkKm99_48kmO2Y3L9RsnE5f.lHk1sxpyK_DyKVRs&asPdf=falseAMS369FG03-002_Rev2.0_20090603_201210156706.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0cX&d=%2Fa%2F0X0000000bcv%2FxJ7Su9z2Xv0qA_OAV.xQBp2QDJw8qANPqu7Hc393AM8&asPdf=falsecontroller.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Wj&d=%2Fa%2F0X0000000bcu%2F5I5zqvSjLc75rujYUohJSuHj440eZXFoWlVtTBm1Ti4&asPdf=falseTEK00005.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0iK&d=%2Fa%2F0X0000000bcs%2FxQkqnUF.G.4T4n0nizJYGDhDaamp4AN.dZKykvLfSjk&asPdf=false
