STM32F4 Discovery get Acceleration value (integer)
ahsankhushe
Posted on August 28, 2013 at 19:57
Hi
Can any one tell me how to get the acceleration value ? I want to calculate the distance by using it.
Thanks.
#stm32f4-discovery #clive1
5 REPLIES 5
Posted on August 28, 2013 at 20:19
Have you worked the following example?
\STM32F4-Discovery_FW_V1.1.0\Project\Peripheral_Examples\MEMS\main.c
ahsankhushe
Posted on August 28, 2013 at 20:34
Yeah , but in this example only light toggled with respect to direction of acceleration. I want the value of acceleration in x,y and z-axis so that i could calculate the distance from it.
ahsankhushe
Posted on August 28, 2013 at 20:36
Actually i am making a device like odometer. So my need is to get the distance when the stm32f4 is move.
Thanks.
Posted on August 28, 2013 at 22:10
Ok, but this is your project, you'll need to modify this other one that demonstrates talking to the accelerometer
LIS302DL_Read(Buffer, LIS302DL_OUT_X_ADDR, 6);
XOffset = Buffer[0];
YOffset = Buffer[2];
ZOffset = Buffer[4];
You might need to read the
http://www.eng.auburn.edu/~nelson/courses/elec5260_6260/LIS302DL%20MEMS%20Accelerometer.pdf
for the part to configure it the way you want.
ahsankhushe
Posted on August 29, 2013 at 10:30
Ok thanks but i am totally novice to stm and i am confused about some things and these are :
what is going to be stored in buffer[1] , buffer[3] , and buffer[5] ?
what values are actually being read in Xoffset , Yoffset , Zoffset ?
