hackerli90
STM32F10xxx TIMx PWM input mode
  • May 26, 2015
  • 11 replies
  • 1971 views
Posted on May 26, 2015 at 22:36
Hi
I cannot find the STM32F10xxx firmware library as described here: http://read.pudn.com/downloads106/sourcecode/embed/437624/stm32/STM32F%20Documents/Application%20Note/STM32F10xxx%20TIM%20application%20examples.pdf
I am searching for the ''TIM example 6'' to run STM32F10xxx TIMx PWM input mode.
Could you please post my the direct link to that file?
Thank you
    Tesla DeLorean
    Guru
    May 31, 2015
    Posted on June 01, 2015 at 01:59
    I've posted a lot of examples to the forum, the local search isn't much use, Google generally works more effectively.
    Here's an F4 example for USART2, showing the pin configuration, both the pin itself, and the AF (alternate function) mapping to it.
    [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Discovery/USART%20example%20code%20for%20Nucleo%20F401RE&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&currentviews=1016]https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM32Discovery%2FUSART%20example%20code%20for%20Nucleo%20F401RE&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F¤tviews=1016
