[STM32F103VE] SPI1 strange behaviour
yooz
Posted on February 24, 2012 at 00:53
The original post was too long to process during our migration. Please click on the attachment to read the original post.
Posted on February 24, 2012 at 01:09
I'm not sure I want to dig through all the register level stuff, that's why I use the library.
Consider for a moment what the level conversion circuit is doing, if for example it could back-drive the STM32's output, and how it's implemented. The problem sounds more electrical than software.
Consider if you have a common and effective ground.
yooz
Posted on February 24, 2012 at 10:54
Thank you for the answer and suggestion, I will check once again the ground.
The level converter is KAmodLVC, if you are curious this is the product site:
http://kamami.com/index.php?ukey=product&productID=63662
And the manual (in polish, but includes schematic):
http://www.kamami.pl/dl/kamodlvc.pdf
So, let's go with the checking...
