STM32F0 ADC Temperature Drift?
danielblesener9
Posted on May 08, 2014 at 17:48
Simple question - should be answered in datasheet, errata sheet, or ref manual but I cannot seem to find it. I am wondering how much ADC readings drift relative to the reference voltage with temperature. If I have a constant 2.500Vref that does not change with temp, how will my readings change with temp?
Thanks.
chen
Posted on May 09, 2014 at 12:52
Hi
Could not look it up for you because you did not specify which part you actual have (there are 7 F0 part datasheets).
''how much ADC readings drift relative to the reference voltage with temperature.''
''If I have a constant 2.500Vref that does not change with temp, how will my readings change with temp?''
The closest thing I can find in a data sheet is
''5.3.21 Temperature sensor characteristics'' (from STMF405 datasheet - please look for it in datasheets for your part)
The table has an entry ''VSENSE linearity with temperature''
To me, this implies that they have characterised the accuracy/linearity with temperature.
(Vref does not affect it much)
Hope this helps
