STM32CubeMX V4.6.0 for STM32F103 , Set PC2 EXTI2 bug
wjandsq
Posted on February 02, 2015 at 12:41
stm32cubemx v4.6.0  stm32f103vc
PC3 EXTI2 make code success!
PC2_EXTI2 make code failure?
  * @file    stm32f1xx_it.c
  * @date    02/02/2015 19:36:44
  * @brief   Interrupt Service Routines.
  * COPYRIGHT(c) 2015 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS ''AS IS''
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
&sharpinclude ''stm32f1xx_hal.h''
&sharpinclude ''stm32f1xx.h''
&sharpinclude ''stm32f1xx_it.h''
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
/* External variables --------------------------------------------------------*/
&sharpn/******************************************************************************/
/*            Cortex-M3 Processor Interruption and Exception Handlers         */
* @brief This function handles EXTI line2 interrupt.
void EXTI2_IRQHandler(void)
&sharpt/* USER CODE BEGIN EXTI2_IRQn 0 */
&sharpn&sharpt/* USER CODE END EXTI2_IRQn 0 */
&sharpt
get(halHandler) failed on instance of com.st.microxplorer.mcu.NvicVector
The problematic instruction:
==> ${vector.halHandler} [on line 123, column 9 in stm32xx_it_c.ftl]
Java backtrace for programmers:
freemarker.template.TemplateModelException: get(halHandler) failed on instance of com.st.microxplorer.mcu.NvicVector
at freemarker.ext.beans.BeanModel.get(BeanModel.java:223)
at freemarker.core.Dot._getAsTemplateModel(Dot.java:76)
at freemarker.core.Expression.getAsTemplateModel(Expression.java:89)
at freemarker.core.Expression.getStringValue(Expression.java:93)
at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
at freemarker.core.Environment.visit(Environment.java:196)
at freemarker.core.MixedContent.accept(MixedContent.java:92)
at freemarker.core.IfBlock.accept(IfBlock.java:82)
at freemarker.core.IteratorBlock$Context.runLoop(IteratorBlock.java:160)
at freemarker.core.Environment.visit(Environment.java:351)
at freemarker.core.IteratorBlock.accept(IteratorBlock.java:95)
at freemarker.core.Environment.visit(Environment.java:233)
at freemarker.core.CompressedBlock.accept(CompressedBlock.java:73)
at freemarker.core.Environment.process(Environment.java:176)
at freemarker.template.Template.process(Template.java:232)
at com.st.microxplorer.codegenerator.CodeEngine.freemarkerDo(CodeEngine.java:223)
at com.st.microxplorer.codegenerator.CodeEngine.genCode(CodeEngine.java:162)
at com.st.microxplorer.codegenerator.CodeGenerator.generateOutputCode(CodeGenerator.java:1293)
at com.st.microxplorer.codegenerator.CodeGenerator.generatePeriphConfigCode(CodeGenerator.java:805)
at com.st.microxplorer.codegenerator.CodeGenerator.generateCodeFiles(CodeGenerator.java:596)
at com.st.microxplorer.codegenerator.CodeGenerator.generateCode(CodeGenerator.java:406)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.generateCode(ProjectBuilder.java:606)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createCode(ProjectBuilder.java:532)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:323)
at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:32)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:825)
at freemarker.ext.beans.BeanModel.invokeThroughDescriptor(BeanModel.java:272)
at freemarker.ext.beans.BeanModel.get(BeanModel.java:183)
... 34 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 1
at com.st.microxplorer.mcu.NvicVector.GenericGeneratorExtiTsc(NvicVector.java:789)
at com.st.microxplorer.mcu.NvicVector.getHalHandler(NvicVector.java:203)
... 41 more
in STM32CubeMX V4.7.1?This bug is not exist! Thinks!
#pc2-exti2-stm32cubemx-bug
0 REPLIES 0
