STM32CubeF0 1.8.0 Smart Card Problem
mtien888
Posted on July 20, 2017 at 00:44
I start a new project with smart card function generated by CubeMX with STM32F072RB. The smart card circuit is the same as previous project.  And I have no problem with smart card function in previous project.  I compared all the source code and finally realized the firmware is different version.  The previous firmware version is 1.6.0 and smart card is working well.  The new project using firmware 1.8.0 and smart card is not working with any command.
I compared the driver generated and smart card code changes a lot.  Is there any where I can report this issue to CubeMx team?
Imen.D
Posted on July 20, 2017 at 10:15
Hello
Tien.Michael
You can report your issue in the STM32 forum, then ST moderators will take in charge to answer you or raiseyour feedback/issues internally to the appropriate team.
Your description of the issue is general. Would you mind giving a little more detail about your issue, so we can better explain it to our development team? Could you please precise your which CubeMx version are you using?
Imen
Imen
mtien888
Posted on July 21, 2017 at 01:05
I create a github repo for this problem.
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST.git
 Problem
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST#software
Software
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST#hardware
Hardware
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST#connection
Connection
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST#answer-to-resetatr-of-at88sc0104c
Answer To Reset(ATR) of AT88SC0104C
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST#read-card-manufacture-code-command
Read Card Manufacture Code command
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST#firmware-stm32f0-cubef0-version-160-init-commit
Firmware STM32F0 CubeF0 version 1.6.0 (init commit)
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST#firmware-stm32f0-cubef0-version-180
Firmware STM32F0 CubeF0 version 1.8.0
STM32CubeF0 firmware version 1.8.0 generated code doesn't work for smart card command. But it was working at previous version 1.6.0. (I haven't tried 1.7.0)
('init commit' is firmware version 1.6.0. 'firmware 1.8.0' is for firmware version 1.8.0)
Problem
Software
Hardware
Connection
  • STM32CubeMx version 4.21.0, STM32CubeF0 version 1.6.0 and 1.8.0
  • Keil uVision V5.23.0.0
Problem
Software
Hardware
Connection
  • STM32F072RB Discovery Board
  • ST8024L smart card interface
  • AT88SC0104C smartcard
Problem
Software
Hardware
Connection
STM32F072RBPIN NAMEST8024L
PB9(62)SCARD_RESETRSTIN (20)
PC13(2)SCARD_3_5V5V/~3V (3)
PC14(3)SCARD_OFF~OFF(23)
PC15(4)SCARD_VCC~CMDVCC(19)
PA9(42)SC_UART_TXI/OUC(26)
PA8(41)SC_UART_CKXTAL1(24)
Problem
Software
Hardware
Connection
Both firmware version have no problem to receive ATR 0x3B, 0xB2, 0x11, 0x00, 0x10, 0x80, 0x00, 0x01.
Problem
Software
Hardware
Connection
  • 0x00 0xB6 0x00 0x0C 0x04
  • This manufacture code is configured by user. Currently the test card had the code 7f 94 89 10.
Problem
Software
Hardware
Connection
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST/blob/master/pics/fw1_6_0.png
Problem
Software
Hardware
Connection
https://github.com/MichaelTien8901/STM32F0-Smartcard-TEST/blob/master/pics/fw1_8_0.png
The data bus is not the same with different version of firmware. Data in firmware 1.8.0 seems corrupt and data can't be seen in UART.
Customized Code
Only main.c has custom code for the test.  Other files are generated by CubeMx.
