2014-10-13 5:58 AM
I have installed STM32cubeMX and have some functionality. When I do a configuration and then try to generate code the cube window locks up. I left things for 40 minutes but no change. A project file (.ioc ) is generated along with 2 small c files, but not the whole project. The target is MDK-ARM.
I have windows 7 professional 64 bit service pack 1, 8Gb ram, 8 core Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz Any ideas?2014-10-13 6:17 AM
They'll ask you to attach the .IOC
What version of Java? What version of Keil? What board/chip?2014-10-13 6:21 AM
2014-10-13 6:26 AM
MDK lite V5.11.1.0
STM32F4 discovery, with STM32F407VGT62014-10-14 7:56 AM
We do not reproduce your issue. Can you please provide the .log file generated by MX in your user directory in .stm32cubemx folder Can you also reproduce your error launching MX via the command line: java -jar STM32CubeMX.exe > output.log Thanks2014-10-14 11:58 PM
Thanks for the reply. I zipped the whole project, I hope that you can find what you need.
Do you think it's worth a complete re-install? Regards, Bob. ________________ Attachments : f4_usb.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzSp&d=%2Fa%2F0X0000000bMB%2FjOk5XlWxpII7SKOCqQA_0KkDhkp8cTkke8vDF0HHwv0&asPdf=false2014-10-20 1:56 AM
