2010-12-10 1:08 PM
STM3210E Evaluation Board Standard Peripheral Library
2011-05-17 5:18 AM
And you are using what tool chain?
2011-05-17 5:18 AM
Sounds similar to this:
[DEAD LINK /public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/How to use STM32F10x Standard Peripherals Library&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%2520CortexM3%2520STM32/AllItems.aspx¤tviews=270]https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fARM%20CortexM3%20STM32%2fHow%20to%20use%20STM32F10x%20Standard%20Peripherals%20Library&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&TopicsView=https%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FARM%2520CortexM3%2520STM32%2FAllItems%2Easpx¤tviews=270 which sounded like he was muddling-up different library versions...2011-05-17 5:18 AM
Hi Clive1,
My apologies for the delayed response. I am using the IAR Assembler and IAR C/C++ Compiler for ARM version 6.10.1.52143 (EWARM) with the IAR Jtrace. I had already read the post neil.andrew mentioned and I am sure I was not mixing libraries. But I think it was a project configuration issue since I got it to work when I used the Std peripheral library template as the starting point. Thank you both for looking at my query and responding !!! Cheers, EWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
