2015-12-30 08:16 PM
Hi guys,
I used AC6 system workbench to development STM3210C_eval evaluation board.Now I try to use Fatfs to get SD card Capacity->res = f_getfree(''0:/'', &fre_clust, &fs);In debug mode, I get:Name : res Details:FR_DISK_ERR Default:FR_DISK_ERR Decimal:1 Hex:0x1 Binary:1 Octal:01 what's happened? Does someone can help me?Thank all.2015-12-30 08:25 PM
Ok, and you've mounted the media? Any of the other access functions work? ie can you open and read a file?
Have you tested your SD access functions outside of diskio.c? Can you instrument the routines in diskio.c to see which are succeeding, and which are failing?2016-01-06 02:00 AM
Thanks for your reply.
I fix it off. Before use Fatfs Functions, it should f_mount() first.
