STM32 virtual com port
lowpowermcu
Posted on June 05, 2011 at 15:32
Hi all,
Is there somebody who can give the link for the virtual com port for STM32 device.
I didn't find it :(
MCU Lüfter
po
Posted on June 05, 2011 at 19:52
Hi MCU Lüfter,
You find it
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00158241.pdf
A useful doc for HID.
http://www.st.com/stonline/books/pdf/docs/14711.pdf
But I have a problem:
when I connect my primer 1 to the computer I get:
USB device not recognized
Currently, this hardware device is not connected to the computer. (Code 45)
I heared that there is a ''.inf'' file to install. Is that right?
Thanks for you participation.
Thanks,
Po
saimaddy123
Posted on June 06, 2011 at 04:57
Hi MCU,
Which STM32 device are you using?
I have posted a code here that will make STM32F107's USB to act as a Virtual COM port. You just need to setup the GPIO pins corresponding to your USB properly.. It should work right away:
https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/stdio over USB serial in STM32-H107&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&currentviews=87
Sai
vikas_sinha75
