STM32 virtual com port
‎2011-06-05 6:32 AM
Hi all,
Is there somebody who can give the link for the virtual com port for STM32 device. I didn't find it :(MCU Lüfter- Mark as New
‎2011-06-05 10:52 AM
Hi MCU Lüfter,
You find it http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00158241.pdf A useful doc for HID. http://www.st.com/stonline/books/pdf/docs/14711.pdf But I have a problem: when I connect my primer 1 to the computer I get: USB device not recognized Currently, this hardware device is not connected to the computer. (Code 45) I heared that there is a ''.inf'' file to install. Is that right? Thanks for you participation. Thanks, Po- Mark as New
‎2011-06-05 7:57 PM
Which STM32 device are you using?
I have posted a code here that will make STM32F107's USB to act as a Virtual COM port. You just need to setup the GPIO pins corresponding to your USB properly.. It should work right away:
https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/stdio over USB serial in STM32-H107&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E¤tviews=87
Sai- Mark as New
‎2011-07-06 1:12 AM
go to for downloading firmware and for V COM Port Driver
