STM32 USART1 in single-wire half-duplex
Sudhakar.R
0693W00000aIND8QAO.pngi need to transmit above given example data using single-wire half-duplex communication.
if you known any one help me.
Doesn't look like a standard UART serial form. Looks more Manchester or PWM encoded. For transmission I'd perhaps use the TIM, or DMA+GPIO pattern buffer.​
Javier1
Principal
If you need to transmit only, take a look at any implementation of the WS2812B protocol , what youre trying to accomplish looks very similar
here is mine:
https://www.hackster.io/javier-munoz-saez/coding-your-own-neopixel-driver-baremetal-stm32-b6b4d0
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
Sudhakar.R
@Community member​  and @Javier Muñoz​
thank you for your comments this is very useful.
