STM32 MCUs can operate in vacuum environment?
I would like to know if MCUs of ST can operate in a vacuum environment.
Thanks​
4 REPLIES 4
S.Ma
Principal
Check datasheet in case it has some info. I would guess it should work as there is no gas in chip and package. In case if radiations, it is another story.
Andrew Neil
Evangelist III
Apart from the datasheet - as @S.Ma​ mentioned - try searching to see if there are any specs for the packaging?
GLASS
Hi, not sure that you can find something in datasheet about using stm32 in a low pressure condition...
What about solder and chip can deliver in low pressure ambiant.
But you also must consider how heat can be conducted away...​
S.Ma
Principal
Not directly related, may explore parylene coating for few micron to make coating. Normally used for medical grade electronics. Simple and common process in chamber.
