STM32 and rotary encoder from Alps
Options
‎2013-05-25 2:00 AM
Posted on May 25, 2013 at 11:00
i have problem with control of simple rotary encoder form Alps (or Piher | Bourns) on STM32.Does anyone
have a
ready
solution.
Best regards Andrew #poorly-framed-question #stm32
Options
‎2013-05-25 4:07 AM
Posted on May 25, 2013 at 13:07
There are literally dozens of STM32 parts, do you have a specific series or part in mind?
[DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32F107%20Quadrature%20encoder%20example&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=48]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex%5Fmx%5Fstm32%2FSTM32F107%20Quadrature%20encoder%20example&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=48
Options
‎2013-05-25 3:45 PM
Posted on May 26, 2013 at 00:45
Thank you for answer. I make some tests. Now i have problem with vibration of encoder contacts. Timer count random statest. My encoder have mechanical contacts. Kind regards Andrzej NiedworokOptions
‎2013-05-26 6:23 AM
Posted on May 26, 2013 at 15:23
OUCH!! thta limits your speed to 'bounce time' of the contacts. can you live with this. also if you believe in the old wifes tale that you can read an encoder by a=clk, b=dir you are dead wrong. Erik
