STM CubeMX developer guide
Abhishek Rajgopal
Posted on February 08, 2017 at 12:03
I am using CubeMX for my STM32f411 discovery board. Once the code is generated, How i can use application driver, Is there any developer guide is available ? .I am beginner ,Please tell me the information ,which are all the necessary guide to program the peripheral   like SPI,USB,I2C,So on.
Oliver Beirne
Posted on February 10, 2017 at 17:27
Hello
I have moved your question to the
https://community.st.com/community/stm32-community/stm32-forum?sr=search&searchId=77ba8b04-80a7-44d8-8bed-4b6dd545e9ee&searchIndex=0
‌ where someone should be able to help you.
Posted on February 10, 2017 at 17:48
I would suggest you review the peripheral and board examples provided under the Cube directory. Review the form and function of the code.
Imen.D
Posted on February 11, 2017 at 18:32
I'd hi
ghly recommend you to have a look to the
http://www.st.com/content/ccc/resource/technical/document/application_note/ca/34/db/d3/71/50/44/9b/DM00213525.pdf/files/DM00213525.pdf/jcr:content/translations/en.DM00213525.pdf
  for more information about
STM32CubeF4 firmware examples available for STM32F4 Series. You may start from the template project, then add your own modifications.
Also, you can refer to your related reference manual and
'Getting started' documents with
STM32f4xxx
series hardware that may help you to go step by step to develop your project:
http://www.st.com/content/ccc/resource/technical/document/application_note/76/f9/c8/10/8a/33/4b/f0/DM00115714.pdf/files/DM00115714.pdf/jcr:content/translations/en.DM00115714.pdf
: Getting started with STM32F4xxxx MCU hardware development.
http://www.st.com/content/ccc/resource/technical/document/user_manual/96/03/db/05/12/8d/40/9a/DM00107720.pdf/files/DM00107720.pdf/jcr:content/translations/en.DM00107720.pdf
. This user manual describes how to get started with the STM32CubeF4 firmware package.
Hope this helps you.
Best Regards
Imen
Imen
