2018-04-19 1:25 PM
Hi, I have some trouble when I set my PWM to 100% output for my STM32L4 to the input STLD41. I use a 40KHz frequency for my pwm and a periode of 400 cycles. Between 0 to 398 cycles compare everything run smoothly. at 400 cycles compare, the led start flickering.
Is the STM32 having hard time with the pwm at 100% or the STLD41 able to handle Vdc? Is this suppose to work and I have some layout problems with my board?
For now I have set a firmware limiter to 398 cycles to make sure I don't get this flickering, but I was wondering what we did wrong with this design.
Thanks,
Jerome
#stld41 #pwm #stm32l4
