SPI communication between two STM32F3 problem
Options
‎2013-11-21 3:42 AM
Posted on November 21, 2013 at 12:42The original post was too long to process during our migration. Please click on the attachment to read the original post.
4 REPLIES 4
Options
‎2013-11-21 6:43 AM
Posted on November 21, 2013 at 15:43
The master might want to make sure RXNE is cleared prior to sending the junk bytes
Options
‎2013-11-21 8:10 AM
Posted on November 21, 2013 at 17:10
Thank you clive for your response. I'm not sure understanding your remark.
Do you mean , i have to change the order like this? while (RxIdx <BufferSize) { /* In this step, the Master recieves data from the Slave*/ /* Wait for SPI1 data reception */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); /* Read SPI1 received data */ SPI1_Buffer_Rx[RxIdx] = SPI_ReceiveData8(SPI1); RxIdx++; /* send a byte */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); //SPI_SendData8(SPI1,SPI1_Buffer_Tx[TxIdx++]); // Send Dummy SPI data to get back data from DR Register SPI_SendData8(SPI1,0x01); } If yes, it doesn't work, it gets stuck in RXNE.Options
‎2013-11-21 8:52 AM
Posted on November 21, 2013 at 17:52
while(RxIdx <BufferSize)
/* send a byte */
while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); // Spin Till TX Empty, should be after RX
if (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) != RESET) // Clear any hanging RX
while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
RxIdx++;
/* Turn on LED5 */
STM_EVAL_LEDOn(LED5);
Options
‎2013-11-21 9:34 AM
Posted on November 21, 2013 at 18:34
I tried you solution but unfortunately, i have only zero.
May be i need to make some delay to wait the slave clock to start transfer because i think that during two cycles, the clock still inactive this why i have 2 zero in the beginning. I don't how and where ?
