SPI_CLK(STM32L4)
Options
2017-07-20 3:42 AM
Posted on July 20, 2017 at 12:42
Hi sir I'm working on STM32L476RG .While im using SPI peripheral in that im facing issue i.e in the clock gereration.
when clock generating according to resolution setting(ex-16 bit) after that 16 clock pulses its having some more delay (12us)after that again 16 clock pulses generating and again more delay ..every time its continuing ..whats the solution for that.
1 REPLY 1
Options
2017-08-03 1:38 AM
Posted on August 03, 2017 at 10:38
The SPI has 32 bit FIFO (Tx/Rx) so it should be possible to push 2x16 bit if sending data by polling or interrupt.
Otherwise, for maximum throughput, DMA should be used to run data block transfers.
