run from flash
suyongyao
Posted on June 15, 2008 at 00:59
run from flash
suyongyao
Posted on May 17, 2011 at 12:37
Hi John,
I'm using IAR KickStart board, IAR JLINK. These are the settings in order to download ur code into flash.
1. Make sure u select the proper device. In this case, i'm using ST STM32F10X.
2. Check the box ''Use flash loader''.
Btw, i'm using Embedded workbench 4.42a kickstart 32k
st3
This seems to be a reply to a question - but you've started a new thread, so we don't know what the question was!
suyongyao
Hi st7,
ya, u're right. I'm new here. I wanted to delete this but do not know how. Anyway, the reply is refering to ''STM32-SK Kickstart run from flash'' posted by john.speth
Yao
