Ride 7 RKit and ST library temple problem
robinsm
Posted on August 31, 2009 at 07:43
7 REPLIES 7
robinsm
Posted on May 17, 2011 at 13:21
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6Yd&d=%2Fa%2F0X0000000bqg%2FIvcbisPZkRrT37G3pd84KOUSkeP9vn4WzQPBj2hBH0s&asPdf=false
16-32micros
Hi robinsm,
Could you check that you have the right and latest version of Ride7, Here is my version and it working fine.
Hoe this helps you.
Cheers,
STOne-32.
[ This message was edited by: STOne-32 on 26-08-2009 22:01 ]
[ This message was edited by: STOne-32 on 26-08-2009 22:02 ]
robinsm
I have newer versions.
robinsm
The template that comes with RIDE7 works fine (compiles okay), but the one in the new library (3.1.0) does not.
robinsm
I did a fresh install of everything, and still no luck.
robinsm
I will use the default template until the issues with the new library are resolved.
16-32micros
Hi robinsm,
It seems a Ride7 tool-chain limitation in the latest version and for sure would be fixed in a new version from Raisonance, You can post you message here :
http://raisonance-forum.xsalto.com/index.php
Cheers,
STOne-32.
