R
mrhoang
Posted on November 04, 2012 at 14:31
  I think it's impossible. I suggest other solution : using external logic IC such as 7408 to create a logic expression (Button 1) AND (Button 2)AND....AND (Button n) and it's output connected to EXT0 pin. And in the interrupt service, you  check which button state is Low and write code
0 REPLIES 0
