Question about usage of pins like TIM2_CH1_ETR, TIM8_CH4_BKIN2, etc
Options
2013-06-08 09:29 AM
Posted on June 08, 2013 at 18:29
The datasheets don't detail how these pins are connected internally. Can someone shed some light on this?
Can I use these pins as output compare outputs? i.e. PWM outputs?
1 REPLY 1
Options
2013-06-08 10:36 AM
Posted on June 08, 2013 at 19:36
Question about usage of pins like TIM2_CH1_ETR, TIM8_CH4_BKIN2, etc The datasheets don't detail how these pins are connected internally. Can someone shed some light on this?
TIM2_CH1 and TIM2_ETR are connected together for the purpose of interpreting the black box diagram of the timer unit.Can I use these pins as output compare outputs? i.e. PWM outputs? Yes
