Question about button function turn on, turn off LED
kquirosp
Posted on June 20, 2015 at 17:15
How can I turn on or turn off a LED through button function
Posted on June 20, 2015 at 17:37
Configure the respective GPIO pins as inputs/outputs, sit in a loop monitoring the key input, and then transition the state of the LED output.
Might I suggest you review software library examples for the chip/board you're using.
