mhabermann74
Problems writing RTC_PRL at runtime
  • January 20, 2010
  • 716 views
Posted on January 20, 2010 at 02:58
    mhabermann74
    Posted on May 17, 2011 at 13:38
    I found the solution. Writing to the backup and RTC registers must be enabled with:
    PWR_BackupAccessCmd(ENABLE);
    mhabermann74
    I intend to calibrate the RTC by adjusting the prescaler in the RTC_PLR register. But any write to this register while enabled RTC, causes the RTOFF bit to hang.
    This code hangs:
    RTC_WaitForSynchro();
    RTC_WaitForLastTask();
    RTC_SetPrescaler(ReoTime_maxRtcPrl);
    RTC_WaitForLastTask(); //hangs forever
    This code also:
    RTC_EnterConfigMode();
    RTC->PRLL = (u16)ReoTime_maxRtcPrl;
    RTC_ExitConfigMode();
    Without writing to RTC_PRL, i.e. using the configuration created with STM32_Init.c unmodified, the RTC works as expected.
