problems with TIM2 oc pin output
Options
2010-11-23 7:45 AM
Posted on November 23, 2010 at 16:45
4 REPLIES 4
Options
2011-05-17 5:15 AM
Posted on May 17, 2011 at 14:15
Hi kuczek,
Try to changeTIM_OCInitStructure.
TIM_OCMode
= TIM_OCMode_Timing;
byTIM_OCInitStructure.
TIM_OCMode
= TIM_OCMode_PWM1;
MCU LüfterOptions
2011-05-17 5:15 AM
TIM_TimeBaseInitStruct.
TIM_Prescaler
= 72 - 1; // 72 MHz
input, 1 MHz output
Options
2011-05-17 5:15 AM
hi,
Plese note that i try to use chanel no 2 for generating signal on pin 1 of port A. regards krzysiekOptions
2011-05-17 5:15 AM
Posted on May 17, 2011 at 14:15 Hi, I'm going to have 1Mhz clocked timer, so the value is ok, but of course comments is not it should be like this TIM_TimeBaseInitStruct.TIM_Prescaler = 72; // 72Mhz/72 = 1Mhz Regards krzysiek
