Problems submitting questions to this board
NathanWolcott
This is just a test. Has anybody else been unable to submit questions? I keep getting a red error message.
Guru
You're missing something, but it's not obvious. The down arrow on the top-right of the post lets you edit topics.
7 REPLIES 7
NathanWolcott
Lol, naturally the test question worked perfectly. Of course, my actual question is still failing with the error:
  • x7sActivityTopicsTrigger: System.LimitException: Too many query rows: 50001
NathanWolcott
After a little more tinkering, it looks like the error is caused by selecting any topic for the post. The post works if no topics are entered. Weird bug.
Guru
You can edit topics after you submit the post as a workaround.
That's a good idea, but I don't see the topic field when I edit a post after submitting it. Am I just missing something obvious?
Guru
Thanks, that worked great. I stupidly assumed it would be under the regular Edit command and didn't notice the separate Edit Topics option. Excellent UI design, as always...
The other point of note is that your can't make up topics, only select existing ones
