Power Over Internet ( POE)
infoinfo964
Posted on October 16, 2010 at 19:01
Posted on May 17, 2011 at 14:11
Not sure my internet is powered, ethernet perhaps?
Generally you want them to be robust and fault tolerant, TI has a host of solutions. Do you need it to be 802.3af/at compliant, or you just want to push power over the cable. There are solutions which just push DC over the unused pairs, and crude implementations pretty much just use a regulator at the peripheral end. If you are using unshielded cables that might also be a concern if you have appreciable current, or RF leaking out.
http://focus.ti.com/analog/docs/gencontent.tsp?familyId=64&genContentId=938
http://www.ti.com/ww/en/analog/poe/index.htm
Andrew Neil
@AlexDion - In case you don't get  Clive1's hint, the clue is in the name (or, rather, the acronym):
''Power Over
I
nternet (Po
E
PoE stands for Power over Ethernet - not Internet!
