Play wav sound from SD Card STM32F2xx
damien2399
Posted on January 23, 2012 at 16:04
I want to play wav files from an SDCard with my STM32F2xx.
I used SDIO example and I added FatFs support on it and it's OK.
Next, I tried to use STM audio example to play audio from memory, and it's work (first I had a problem with I2C and I fixed it).
Those two examples work fine but, when I want to add SD support on audio example, SD don't work anymore, and when I add audio on SD example, audio don't work ...
Maybe someone already tried this on a STM32F2xx.
Thanks.
akshaya
Posted on March 08, 2012 at 14:37
Hi Damien
Were you able to achieve playout of wave through SD Card. I am trying the same on an STM32F4XX but I am facing problems.
My playout is start-stop and not continuous. Let me know if you were successful.
holger
Posted on August 21, 2012 at 11:38
Hi damien,
have you solved your SDIO+I2C problem?
Why this question?
I've problems reading the SDCard, while using a touchscreen I/O interface, that uses I2C.
Best regards,
Holger
