NUCLEO-L452RE-P problem with PC6
LWagn.1
Hi, I have problem with NUCLEO-L452RE-P, the PC6 pin does not respond to HAL commands, other pins on Port C works, is there any way how to check what the problem might be?
6 REPLIES 6
Ons KOOLI
Senior III
Hi LWagn.1,
For what IP you are using PC6 pin ?
Best Regards,
Ons.
LWagn.1
Hi, IP? Im using it as a normal output...
Ons KOOLI
Senior III
Hi LWagn.1,
What are HAL commands this pin does not respond for?
Best Regards,
Ons.
LWagn.1
The commands are:
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_6, GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_6, GPIO_PIN_RESET);
Libor
Ons KOOLI
Senior III
Hi LWagn.1,
Okay. And how do you know that this specific pin does not respond to HAL GPIO commands ?
Best Regards,
Ons.
LWagn.1
I use multimeter to mesure its output.
Lbor
