NAND flash library
francescatodiego
Posted on January 06, 2014 at 10:32
I was looking information about this library.
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00091013.pdf
Anyone know if it is available freely (if yes where) or if I must buy the dev board
Posted on January 06, 2014 at 12:30
As far as I'm aware most of the eval board firmware/examples are downloadable whether you actually have the hardware or not.
For things offered, but with out code, the general method would be via an ST rep or FAE through normal sales channels.
NAND is relatively generic, have you looked at the code in the Demonstration Builder package?
STM32F2-F4_Demonstration_Builder_V1.3.0\Utilities\STM32_EVAL\STM322xG_EVAL\stm322xg_eval_fsmc_onenand.c
francescatodiego
Posted on January 06, 2014 at 19:09
Thanks for info Clive but I haven't found what I'm looking:
garbage collection, wear leveling, bad block management, ECC checking
the stm322xg_eval_fsmc_onenand.c contain baisc communciation interface for NAND flash
Tomorrow I
will ask the
ST rep
