Öyild.1
MCP2515 Module Library
  • August 23, 2021
  • 7 replies
  • 7488 views
I would like to use MCP2515 module which can be found here. Is there any tested official or nonoffical library that I can use with stm32f429-disco developer kit? Thanks inadvanced.
"stm32 mcp2515" returns quite a few results.
https://github.com/thumptech/STM32-MCP2515
Öyild.1
Öyild.1Author
I have tried that one but it has not completed. There is missing files like "can.h".
SaidErsoy
Hi, i have same issue you had. Did you solve it or find another file?
Tesla DeLorean
Guru
March 21, 2022
FPicc.1
Hi, I'm having the same issue, have you found a solution yet? I'm using a STM32WL55 board, and using this library: https://github.com/eziya/STM32_SPI_MCP2515
Tesla DeLorean
Guru
February 24, 2023
That it can't find "can.h", or something else?
FPicc.1
Actually the can.h is on the reference that the github above used, but I didn't try with this code.
I too am trying to comunicate the MCP2515 with the STM, with the library that I sent before​, but it isn't working for my case. I already spoke to the owner of the code and it works fine for the stm32f1xx. I made the alterations for the wlxx, but I still can't receive any data.
