Linker script: How to get the same size of BIN file?
lubos
Posted on November 15, 2011 at 12:33
I need( from some reason) to get always the same size of bin file.
I've tried to create other flash-section and fill it with some value.
As last section I added following..
  .added :
    FILL(0xAB);
    . = ALIGN(0x20000) - 1; //128kB
    BYTE(0xAB); //write something to say linker its really section
  } >FLASH
But than original linker script continue with
  /* used by the startup to initialize data */
  _sidata = .;
  /* Initialized data sections goes into RAM, load LMA copy after code */
  .data : AT ( _sidata )
    . = ALIGN(4);
    _sdata = .;        /* create a global symbol at data start */
    *(.data)           /* .data sections */
    *(.data*)          /* .data* sections */
    . = ALIGN(4);
    _edata = .;        /* define a global symbol at data end */
  } >RAM
So my bin file doesnt finished at 0x8020000 but continue with _sidata.
When I switch
 _sidata = .;
with my added section, I get error.
overlaps section .added loaded at [08010694,0801ffff]
#linker-stm32
0 REPLIES 0
