libraries i2c.h
Icont.1
I would need to find the i2c.h library to be able to have the low-level functions i2c.read and i2c.write to read the data of a thermal sensor mlx90640
You can use the HAL libraries. STM32CubeMX should generate the starting code for you. There are example usages in the relevant Cube repository, for example:
https://github.com/STMicroelectronics/STM32CubeF4/tree/2f3b26f16559f7af495727a98253067a31182cfc/Projects/STM32F412ZG-Nucleo/Examples/I2C/I2C_TwoBoards_ComPolling
