jfaycel
LDR-Light Dependent Resistor and STM32Discovery
  • June 3, 2013
  • 3 replies
  • 1138 views
Posted on June 03, 2013 at 20:11
i want to drive a motor for a control of the door  following the LDR sensor signal
( open when it feel light and close it when it's darkness)
I have an STM32F100RB. please i need your help urgently
thanks a lot
    crt2
    Visitor II
    June 4, 2013
    Posted on June 04, 2013 at 11:08
    You need help with what?
    jfaycel
    jfaycelAuthor
    Posted on June 04, 2013 at 21:20
    i need to know how to program the LDR in STM32
    Tesla DeLorean
    Guru
    June 4, 2013
    Posted on June 04, 2013 at 21:38
    You really need to work on your own Master's project.
    You'd presumably want to be using an ADC, and place the LDR (VT9ON1) in a resistor divider, perhaps with an 8.2K to VDDA. You'd then use the ADC to measure a voltage at the junction. The firmware library has ADC examples, you'll need to correlate the voltage to light intensity.
