Layout guide for STM32L053R8
nope noperson
Posted on December 31, 2017 at 02:18
For the life of me I can't find the recommended PCB layout guide for the above chip (STM32L053R8)? Can anyone be so kind and link? Does it exist? Am I searching for the wrong thing?
Best Regards,
Sam
#stm32l0
Zt Liu
Senior III
Posted on January 02, 2018 at 11:14
I am not a PCB expert, but I often check the gerber files of Nucleo board and discovery boards, sometimes even EVAL board. (Just to make sure my hardware colleague makes no mistake.)
Such as followings:
http://www.st.com/resource/en/board_manufacturing_specification/stm32l0538-disco_gerber.zip
http://www.st.com/resource/en/board_manufacturing_specification/nucleo_64pins_gerber.zip
As for general guideline of crystal oscillator, the following document helped me a lost:
http://www.st.com/content/ccc/resource/technical/document/application_note/c6/eb/5e/11/e3/69/43/eb/CD00221665.pdf/files/CD00221665.pdf/jcr:content/translations/en.CD00221665.pdf
For nucleo board, it's simple two-layer PCB, with altium designer project directly offered.
You can directly import it into your favorite design tool.
For discovery board and eval, there are generally only gerber files, you may try to contact ST for other supports.
Hope that helps you!
Zt.
Amel NASRI
Posted on January 02, 2018 at 11:27
Hi
m0sf3tz
Besides to what was suggested by
Liu.Zhitai
‌, I suggest you to refer to
http://www.st.com/content/ccc/resource/technical/document/application_note/fd/f4/6b/40/9a/b5/41/a2/DM00112pdf/files/DM00112pdf/jcr:content/translations/en.DM00112pdf
: 'Getting started with STM32L0xx hardware development'.
-Amel
