Keil Compiler: USB examples do not work in Opt level 0
flyer31
Posted on March 29, 2012 at 19:59
I have some nicely working USB device examples now, but none of them works, if I use the Keil compiler (uVision 4.23) with opt level 0 - for opt level 1-3 they work nicely.
Has anyone observed something similar already? Any hint, what the reason could be?
Posted on March 29, 2012 at 21:01
Perhaps you could check stack utilization, and if data buffers get pushed into different regions of memory (with different DMA access speeds/limitations, or alignments).
See if you can bisect the problem by optimizing different portions of the code.
