It is possible to get C or C++ code from .hex or .elf file or any other file generate when compile code?
Options
‎2019-08-07 8:54 PM
i want to convert .hex file or .elf file in to C or C++ code if it possible. if possible then how can i do this?
Options
‎2019-08-07 11:04 PM
Unfortunately it is not possible to convert hex file to C or C++ code. You could, however, convert .elf to assembly.
1 REPLY 1
Options
