INC /DEC
matthiasjunge9
Posted on July 29, 2008 at 11:24
INC /DEC
matthiasjunge9
Posted on May 17, 2011 at 12:40
an expression like
unsigned int i;
i--;
is compiled as
LDR
SUBS
STR
is there any sort of INC / DEC command to do this in one instruction on the ARM like on other processors?
matt
disirio
SUBS is equivalent to a decrement instruction. LDR and STR are only required if your variable resides in memory and it is not allocated into a register.
So: yes, it has increment/decrement instructions but it is not capable to increment/decrement variables in memory (like most other RISCs, it is a load/store machine).
regards,
Giovanni
ChibiOS/RT
http://chibios.sourceforge.net
