IAP - PC side
greg_t
Posted on October 21, 2010 at 21:30
IAP - PC side
4 REPLIES 4
Andrew Neil
Posted on May 17, 2011 at 14:12
One of the main reasons for using YMODEM (or XMODEM) is that just about every terminal program suports it.
So you can use any terminal program you like (provided it has YMODEM).
See:
https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Hyperterminal%20is%20not%20the%20only%20terminal%20program
Andrew Neil
the XMODEM and YMODEM specifications are available & free on the net, and it's not hard to write your own implementation.
http://www.lmgtfy.com/?q=xmodem+ymodem+protocol+specification
Most serial coms libraries will include X- and/or Y-MODEM...
Andrew Neil
I know - that is a really stupid, misleading, and unhelpfulthing that it says!
Sorry, the forum broke the link I posted earlier - try this one:
https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/Hyperterminal is not the only terminal program!!&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&currentviews=260
lowpowermcu
Hi Andrew,
I have discovered that in the available version in ST site, it is mentioned
''To use the IAP, the user must have a PC running HyperTerminal or other Terminal program that supports ymodem protocol. In this document the HyperTerminal is used.''
regards,
MCU Lüfter
